メインコンテンツにスキップ
What's the cable pinouts?
i have been looking for the pin-outs of the ipod shuffle 4g cable for a day now, and i can't find anything correct, only the 2g witch is apparently not the same one as the 4g. i really need help fast. just to make it easier for you to answer i included a picture, so if you know it please answer
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
最も参考になった回答
Valen S, one of the things to remember is that the Shuffle 4G has a few IC's of unknown type as part of the cable, so we are not sure yet of exactly what they do and how they impact the cable. The pinout itself is as follows ( I am using your markings)
iPod pin 4 to USB pin C => USB DATA - / Left Channel
iPod pin 3 to USB pin B => USB DATA + / Right Channel
iPod pin 2 to USB pin A => GND
iPod pin 1 to USB pin D => Vcc
Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
hmm, weird that nobody has ever taken one apart. the ic stuff is probably a way for apple to earn money :(
さんによる
Yup, that is what makes those cables special and costly ;-)
さんによる
Thanks, guys!!!
さんによる
Did the correct pinout get you comnected or is the PCB necassary to establish a connection?
さんによる
コメントを追加
I have found a PCB with several CMD electronic components like IC's, capacitors and resistors inside USB connector of iPod Shuffle 4g cable.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi im making a homemade cable so is it posible to make it witouth these components? please answer ASAP Thank you
さんによる
Did you do it??
さんによる
コメントを追加
I followed the pin out and had continuity all around, but my computer didn't recognize it being plugged in and no sign of a charge.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Valen S さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 226
今までの合計 19,061
