メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Audio not working when I am recording!?
Ok Here's the deal I have a IPhone 4 and for some reason my mic has stopped working. I have drop my iphone in water but it wasnt fully sumerged. It has been repaired. Now after a day of using my phone something happened. When i record i can't hear any sound whatsoever. But when i put my earphones in i can record and i can hear the audio well. I dont know why this happen. I can hear music very well. I can use voice memos very well. Voice command works very well. I have looked at Youtube and Google for help but they all say to take it apart and i really don't want to do that and then cause more damage. Please Help Me!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
You are using a duplicate username. Doing this will confuse the issue, try to refrain from using multiple usernames.
さんによる
コメントを追加
2件の回答
ベストアンサー
dolld29, you have not mentioned how it was fixed after the water damage. It does not need a full submersion to cause problems. It is possible that this is an issue with your dock connector, your mic or your speaker. You should of course try a reset and a full restore and see if that changes anything. If it does not, you will have to disassemble your iPhone and see if there are any obvious corroded, or missing components.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
Hi, anybody can help? My iphone 4 audio nt working at watsapp....it said that application is not saving or something like tt...help pls... Thk u in advance..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dolld29 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 97
