メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
591回答 すべてを表示
MacBook Pro system upgrade now stuck on boot
I have a Macbook Pro (not sure the year but can find out) that I got from my brother because he fried the firewire connection on the motherboard which shorted out one of the processors (I think but he says it has a back up it uses) and it takes so long to be ready to use it has to start up then go into screensaver for 15 mins then it works fine.
I decided that it I should upgrade the system software I downloaded Mountain Lion and restarted it but it has been stuck on start up (the grey screen and spinning wheel) for 9 hours now. I am hesitant to shut it down because i know its hardware is not sound and will leave it on all night.
I dont want to make an apt with genius bar because of it taking so long to boot up and it doesn't have apple care. Please give me some advice on what to do next.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Replace this cable: MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable
MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cableの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Why would it be the cable? It was working fine until I restarted it. I think its the system software that has the problem now.
さんによる
This is fine? " it takes so long to be ready to use it has to start up then go into screensaver for 15 mins "
さんによる
This computer has been taken into the shop and tried to have that problem addressed. I am more concerned with the fact that it is stuck in boot I think it is a problem with the operating software.
さんによる
Well, you might try my suggestion after all else has failed. When you boot from the system installation DVD, how does it run?
さんによる
コメントを追加
回答を追加する
keith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 258
