Battery charging does not work, is the battery faulty?
When I plug in charger the battery symbol comes up showing low charge in red below 5%. It also indicates that the cable should be connected (when it already is plugged in). In trying to recharge I find that the battery has now completely discharged. Can I rule out the charging dock as I have seen these advice symbols for recharge? perhaps the next stage is to replace the battery?
Have your tied a different cable, check your dock connector? Have you tried a different charger, what charger are you using? When did this this start?
oldturkey03 さんによる
