メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Weak antenna signal after replacing home button
Hi all,
I did replace the home button of my iPhone 4 home button since it was not working. After reassembly of the phone, I noticed that sim antenna signal is much weaker than before. Everything else looks to be fine, the WiFi is also ok.
For example when I am inside the house the signal strength is quite low and disconnects time to time. It was not like this before. Out side I used to get full coverage but its not full coverage now.
Can you please tell me what would be the problem and how can I fix this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Have you tried calling your cell provider and explaining to them? Sometimes the signal strength can be attributed to a down tower or your phone may need a location update. I have had to do this before. Takes a minute to do but sometimes fixes connection and signal issues. Good Luck!
Update
All I can say is I moved and my signal dropped off. I called the cell provider and told them and they had me do something to my phone and make sure I had correct version of software and my signal increased to full scale. Just a suggestion.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Well I can ask people around to see if that's the problem. But I highly doubt this.
さんによる
Do you by any chance remember what you did?
さんによる
I called Verizon which is my provider and told them and they sent something to my phone and I restarted the phone. I think what it is you are given a base tower that all of your calls go through and when you move you may be closer to another tower. It could just be a Verizon thing or I could be assuming something. I deduced this from hearing others complain about this before and getting tidbits of their conversations with Verizon. I can't be sure because I didn't actually ask them when I called. If I get a chance I will call tonight and ask them what they did...providing they will tell me! Who is your provider?
Won't hurt to ask them in any case!
さんによる
コメントを追加
回答を追加する
Sean さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 157
