The Entire Touch Screen Is Unreponsive
I cannot 'slide to unlock' the device. I have tried restoring the device, and turning off/on the device but no solution. Any suggestions?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You probably need a new digitiser there not expensive and easy to fit
このアンサーは役に立ちましたか?
try resetting the digitizer on the logic board ifixit has a guide on how to do it, if this does not fix your issue then you might want to consider a new display. it a may also be a board issue. happy repairing
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 184
