メインコンテンツにスキップ
2012年3月に発売されたオリジナルiPad2の改良版モデルです。より小さくなったダイプロセッサと再デザインされた内部構造が特長です。修理にはヒート(熱)を当てて、十分注意しながらこじ開けて行く作業が必須です。
73回答 すべてを表示
Ipad 2 Damaged Digitizer connectors
Hi,
I damaged the digitizer connectors during an attempted repair. Not only did one of the clips break off (I have seen suggestions on this), but I actually pulled the black tape off the top of the connector (I thought the cable popped off like it does on the Itouch), then the pins themselves starting coming off. I know the connectors can be replaced by soldering but I am hoping there is a work around because the soldering process looks pretty tough.
Any help would be appreciated!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
6件の回答
ベストアンサー
Lisa Graf, if the pins pulled out of the connector, then the only appropriate repair would be to solder it. Place an image of your broken connector and the logic board damage so we can see what you see. There might be other possibilities. the connectors are available at places like this. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi,
I have something similar to tho s,:( is there any life left of this iPad?
any help would be highly appreciated :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What would be the best way to repair it?
solder?
さんによる
コメントを追加
It's hard to see from the picture, but it looks like the fpc on the right was not removed? If that's true and all the pads are intact it's not dead yet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes, I would remove the damaged f p c then solder on the new on being very careful of the pads.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
In the photo above, the fpc is removed. Thats the damage on the logic board. :/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well Nikki, looking at the logic board there, it looks as if the board is beyond repair. It looks like the soldering gun or whatever you used did quit a bit of damage. Once the traces are messed up, then there's no hope of repair from what I've seen. I hope that I can been proved wrong on this by someone with some bada** soldering skills. I'm actually in the same boat with the digitizer connector tab being broken off and having to desolder and solder a new connector on. I'm really apprehensive about doing this though as I really don't have a whole lot of experience with soldering such SMALL parts and with the traces so close together.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lisa Graf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,522
