SSD's for MacBook Unibody.
will this SSD work at SATA II (3Gb/s) in a Macbook uni-body?
link:http://www.amazon.ca/Crucial-256GB-2-5-I...
processor speed:2.0ghz.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Crucial has a compatibility checker on their website. Here's everything that works with your unibody MacBook:
この回答は役に立ちましたか?
are these the only things that work or does the one i have linked work?
I think the problem here is Crucial has a newer model of SSD's and the SSD you are looking at is an older model they no longer make (Crucial v4 256GB 2.5-Inch). From the spec's it should work.
Thank you David for you help, one last question. Will the silicon power t 10 work or is it an external drive?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,096
