My wifi isn't working and its not a software problem?
My wifi isn't working (wont find any networks) and its not a software problem. i was wondering on how to fix this problem by any means necessary. Please help me to do so .
Thanks
there are many possibilities.
anything happened to the phone ?
any damage history ?
droppings ?
fluid damage ?
このアンサーは役に立ちましたか?
Second hand iPhone everything else works fine it seems to kick in when close to a wifi router took it to apple and the checked it for water damage using there usual method and the fella didn't say anything it just seems to work when it wants there are no real marks bumps or bruises on the phone tbh none not even a dint I only got it for two hundred pounds and it don't really bother me if I get it to work but it's nice to know I have it thanks for your help mate
Mine is not seeing any wifi at all and a friend of mine Nokia and iphone do see it my iphone A1303A (3GS) is not seeing the WI-FI at all just keep scanning every 5seconds and it wouldn't see the wi-fi please help us out on this wi-fi issues
このアンサーは役に立ちましたか?
The most common issue is the users does not update the software when requested. Make sure your running the current version of os
このアンサーは役に立ちましたか?
Formating did not work
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,288
it worked last night for about 2 seconds but then went off i was thinking it is an antenna problem that needs replacing
Aaron Taylor さんによる
Just for my own edification, why do you say it's not a software problem?
mayer さんによる
I say software as in the firmware of the iPhone I have been through the process of restore but no luck
Aaron Taylor さんによる
