What part do I need to replace on my display?
hello i open my imac 21.5 intel core 2 duo 3.06 ghz and broke my connect on my display that on the board idk what part do i need to replace to get my displace working again help plz
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Levy Hernandez , the connector on your board is a I-Pex20455-030E and those are readily available for a few $. Problem is that depending on what the damage is on your board, it will be very difficult to solder. You may consider getting somebody with the right tools and the experience to solder that back on.
このアンサーは役に立ちましたか?
Soldering logic board components is not a DIY project. It requires special tools (fine irons) special solder and lots & lots of practice. An electronics repair shop may be able to do this for you. You'd need a new-or replacement board connector/ribbon cable... without pictures I can't tell what you broke.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 118
