メインコンテンツにスキップ
A 4GB 3.6" Touch Video MP3 Player by Sylvania.
2回答 すべてを表示
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
What does a battery cost and where can one be bought?
さんによる
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
さんによる
コメントを追加
It was not working and how to fix it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Um... what are you talking about???
さんによる
コメントを追加
My sony walkman wont turn on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
henryr79 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 15
今までの合計 2,470
