メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Restoring iPod that is disabled and also has a broken power button!
I'm in the possession of an iPod 4th Gen that has a broken power button and is completely passcode disabled.
Is there any possible way to restore it?
You can not use itunes as it will complain about the passcode and I cant manually put it in DFU mode as the power button is broken.
Programs such as Tiny Umbrella and Rec Boot will not recognise the device since it is passcode disabled?
Help... lol
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
2 件のコメント
I need a way to reset my ipod I am disabled my home botton does not work
さんによる
how to restore softwear without home button
さんによる
コメントを追加
6件の回答
ベストアンサー
Here you go mate
http://www.greenpois0n.us/2011/08/downlo...
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Great answer. I would upvote, but apparently there is a 50 per day limit.
さんによる
That makes no sence jack :/
さんによる
I just read into why Recboot was not working for me. Apparently it does not work correctly on x64 versions of Windows :/
さんによる
Not if you can't solder tho
さんによる
コメントを追加
If RecBoot does not work, you need to replace the power button.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thought that may be the case
さんによる
コメントを追加
Repairing the button will always be the straightforward solution
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Folks,
after struggling for 2hrs, I finally found the solution!
I had bought a disabled ipod G2 on an auction site... It looked impossible to unlock it! I couldn't go into the DFU after trying at least a hundred times (eventually, I found out that the home button is lazy...)!
Anyway, after re-reading the same procedure over and over, and working for a device manufacturer myself I was pretty sure there existed a SW only solution to do that (I can't imagine that people in the production need a roughly 30 sec procedure to flash a FW).
I eventually found it! it is called RecBoot. There are 2 versions, 1.3 seems to be the latest for Win7 32bits (the one I used) and there is another one for Mac which is already at v2.2. I loved those guys who made it! it took me about 30minutes to get my ipod working (I needed to reinstall itune)! (just load Recboot, choose the mode and plug the iphone/ipod in)!
Just google it and download it (about 700k).
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
thx!!!its working
さんによる
does this really work
さんによる
awesome, u save my live dude,, thank you very much
さんによる
コメントを追加
recboot is awesome. thank you very much guys
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If Recboot doesn't work, try to use Tenorshare Reiboot
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tim Carruthers さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 34
今までの合計 63,262
