How to ID phone with broken back?
How do ID my iphone 4 if the model number on the back cannot be red because the glass is shattered / missing?
I need to get replacement front glass / back glass.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Since the front glass is broken, it sounds like you'll be needing to replace the Display Assembly (as well as the Rear Glass Panel). The easiest way to tell which model of iPhone you have (given that you have fully disassembled it) is to look at the right side (looking from the front) of the Display Assembly.
In order of the stack:
iPhone 4s
iPhone 4 GSM
iPhone 4 CDMA
このアンサーは役に立ちましたか?
All of those screens are identical and it is only the plastic frame that differentiates them. It is held on with adhesive. You can buy a 4S LCD and put your iphone 4 frame on it and install it and it will work. The technology is identical. The back cover, on the other hand, has clips in different places which are not removable, so you need to get the right one.
I'm not sure if this is what your looking for but here you go . http://support.apple.com/kb/ht3939#iphon...
http://www.ebay.com/itm/iPhone-4-Replace...
that's for verizon but you need to be phone specific because at&t verizon have different backs.
このアンサーは役に立ちましたか?
GSM iPhone 4 has SIM Tray Slot and Antenna Band (black line) on top of iPhone. CDMA iPhone 4 does not have SIM Tray Slot. iPhone 4S has SIM Tray Slot and no Antenna Band (black line) on top of iPhone.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 181
