Antenna Switch PCB on Motherboard
How to exchange the Antenna Switch PCB on the Motherboard?
This is soldered or glued?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
joerg, if you are talking about the Antenna Signal Module also called ""cellular Interconnection Flex, cable" than yes, it is solder. A good soldering iron with a fine tip, and good skills are a must for this. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Any link for part ? Nothing on ebay as I can tell ?
will this work for iphone 5c?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,292
