メインコンテンツにスキップ
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140回答 すべてを表示
Unit not heating up.
Am following the boiler step by step guide. Checking the leads for voltage; there is none. However, when the steam button is on, there is voltage. Question; what is the diagnosis. I determine the boiler is not deficient. Could it be a switch, fuse, or thermostat? Please advise.
Regards,
Brett
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Check the boiler heating element for continuity as well as the fusible link attached to the top of it. If either is open that's your problem, and hopefully it's the fuse as that's much easier/cheaper to replace.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 872
