メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
No Backlight even with new LCD and inverter board + cable
I have so far replaced the LCD screen, inverter board, and inverter cable (individually) on my Early 2008 Penryn macbook 2.4ghz because my backlight keeps failing. I can still see the image dimly and external monitor display is fine.
The backlight will come on upon power up for a short time then go off, and for a short time doing the "brightness down then back up again" thing will work, and after that there's nothing I can do to get the light back on, not even restart.
After I replaced the LCD last night I used to computer solidly for around 3 hours but 4 or 5 times if I touched the screen or moved the laptop even the tiniest amount the backlight went off again. I closed it to go to sleep last night (not shut down) and this morning it is back to not coming on whatsoever.
So:
- clean the fan, logic board and apply thermal paste?
- Try ANOTHER inverter cable?
- Do what 'Rob Orr' suggests here:
www.ifixit.com/Answers/View/69120/No+backlight,+tried+inverter,+what+now
Thanks, I'm soooo frustrated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Hello Andy, I know you said you tried a new LCD, inverter board, and inverter cable. Have you tried a new Display Data Cable?
MacBook Display Data Cable
If the backlight is going in and out when your moving the screen it could be this cable.
MacBook Display Data Cableの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I haven't tried that no. Somebody elsewhere with the same problem said they "ended up stripping the logicboard of the heatsink+fan, wifi card and battery pack before placing it in my dishwasher (by itself, with NO detergent) at 70 degrees for the full cycle...This process steam-cleaned the logicboard for me (kinda like they when manufacture the logicboards" Then they applied new thermal paste between the processor and heatsink.
Depending on further replies, I will buy a display data cable, perform the above clean and replace the cable, all in one go because I'm so fed up of all these hours of disassembly and reassembly.
If that doesn't work I'll either use it as a hard drive or ebay it and hopefully get £100
さんによる
コメントを追加
回答を追加する
Andy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 260
