メインコンテンツにスキップ
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
110回答 すべてを表示
My phone doesn't charge unless it is completely shutdown
it doesn,t charge if it is on
it must be completely off to charge
please help me
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
最も参考になった回答
lylad, it is possible that your battery is discharged to low. "
When your battery is low, the device will emit a warning tone and show a low battery message.Recharge your battery to continue using your device. If the battery is completely discharged, you cannot turn on the device, even while it is charging. Allow a depleted battery to charge for a few minutes before you try to turn on the device. You do want to check your charger and make sure that it is functioning first. also remember that this device is one that does not (or if it does, then it is very very slow) to charge from your computer. you will need to use the Samsung charger. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
there is an option in your settings that if checked the tablet will not charge unless it is off. the fix is to uncheck it. hope this is your problem and it helps you out. :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Where is this option in settings. I've looked in all the settings areas and can't find this option
さんによる
コメントを追加
回答を追加する
lylas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 7,420
