メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
Can I use MacBook Pro ram in my iMac? Also over heating?
I just recently traded my macbook pro on Craigslist for a iMac. The MacBook Pro I used to have is mid 2010 13" dual core. I upgraded the ram to 8gb instead of 4gb before I traded it so I had the original ram from the MacBook Pro. When I got home set up the iMac (took about 5 hours, whole thing was messed up software) after I did that I wanted to see how easy it was to upgrade the ram as the say. So I took off the ram cover and then I thought about my other 4gb of ram from the MacBook Pro. I put it into the other 2 ports (4 toltal) and put the cover back and turned it back on. It booted very very slow than it did before but I clicked the apple and about this Mac and it showed all 8gb working. I restarted it again and it seems a little faster. Is this making the Mac slower or is it fine?
I have 1 more question so when I was wiping the Mac and stuff and setting it up and it got really really hot on the top of the iMac. Even after the installs finished and I waited it still was hot I downloaded istat pro and the hottest component was 62 degrease F. Is this normal?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Focus on solving your memory issue before worrying about the over heating. If you still have a problem after you solve your memory problem let us know.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Your MBP used 1066 MHz PC3-8500 DDR3 SDRAM and your iMac uses 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin).
As you can see the speed is very different. You need to remove the old memory and get the correct memory that is spec'ed for your system.
Heres a good reference on DDR3 SDRAM memory
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
allan jahn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,992
