メインコンテンツにスキップ
モデル番号 A1213/ 8, 16, 32 GB容量
216回答 すべてを表示
締切られた回答
I took apart my iPod touch and now it wont turn on?
I took apart my iPod touch folling the teardown guide and now it wont turn on i have a gold part I cant find out where it goes does any one know this is my only form of music and id like to have it back. thanks in advance for your help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
sorry - i didn't fout that part in any of the teardown pictures i've seen on google.
but as for the main problem - i think it would be a good start di disassemble it again and look at the connectors, check them and assemble it again - that would make the most sense at first
このアンサーは役に立ちましたか?
スコア 1
11 件のコメント:
well i have it still doesnt work the back case is really loose i tried to get the battery off but i stopped half way through it was to hard to get off
さんによる
hmm - that does not sound good - but the battery should get a little bit easier out than the first time
さんによる
well ill try to get the baterie the rest of the way off
さんによる
I think i fount the problem the black cord in between the power button and the wifi card has been damaged just ever so slightly what is the best way to fix this?
さんによる
What cable do you exactly mean (maybe you should post a link to the teardown - then i could figure out a way to fix it)
さんによる
6件以上のコメントを表示
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,820
