メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2376回答 すべてを表示
iPhone 4 won't recognize charger, even after replacing dock connector
Over the past two weeks, my Iphone has been having issues not recognizing the charging cable or dock when plugged in. I started to get the "Charging is not supported with this accessory" message when plugged in to the wall, followed shortly thereafter by the phone not charging when plugged in. The phone is dead now. I tried different cables, different wall adapters, car chargers, and docks all with no luck. I did a little research and found out that the dock connector could have gone bad due to moisture or wear and tear from 3rd party docks. I ordered a new dock connector and installed it by following the how-to on ifixit.com. The phone still doesn't recognize chargers or docks.
I'm not sure if it is a battery issue, because I can still hold the power button down and get the screen showing the emtpy battery with the plug + lightning bolt below it. This leads me to believe that there is still enough juice to power up the screen, so it's not completely drained. Battery life before this problem was average for a 2 year old Iphone 4.
I guess my next course of action will be to try to exchange the new dock connector for another new one to verify it wasn't a faulty part. If that doesn't work I am leaning toward replacing the battery, but I'm not sure if there is anything else I could be looking for.
Does anyone have any advice or ideas about what else could be causing the phone to not recognize the charger when plugged in?
Thanks in advance!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
3 件のコメント
My daughter's phone just started doing the same thing. Any luck with this issue. Don't know if I should replace battery or the port.
さんによる
I have the EXACT same problem as you Doug. I'm also confused by iwillfix's comment. How can you test the charging dock by "just plugging it in". Were you able to fix your phone and if so, how?
さんによる
Daniel I did end up changing the charger port. There were a few pins inside that was messed up.
Doug
さんによる
コメントを追加
2件の回答
最も参考になった回答
i would also try a new dock connector first (dont install, just plug it in). if it still doesn't charge replace the battery...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have heard that you just need a new battery, try replacing it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
efalese さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 3,895
