メインコンテンツにスキップ
The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12回答 すべてを表示
My phone has been damaged by alcohol?
ok so i decided to test out a rumor about bathing your smartphone in isopropyl alcohol beings my phone had a bunch of grit/dirt in it. it work just fine before the bath. now it turns on and it functions with 2 problem tho.1) it has dark blotches all over the display.2) it has trouble reading the sim card(as in it still reads the sim card just poorly) and ideas would be great.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Replace the logic board and display assembly. And never put your phone in a liquid, as it will seriously damage it.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
" never put your phone in a liquid, as it will seriously damage it." not quite correct. It is perfectly okay to submerge and phone or electronic component in something like isopropyl alcohol or sterile water. The only thing with isopropyl alcohol is to use a concentration high enough i.e. 90%+ to clean the device. It will displace water and evaporate quickly. Submersion in any of these liquids does not contribute to failure. It also does not destroy plastics etc. It is really not a rumor to use this to clean your phone.
さんによる
ty jack
さんによる
コメントを追加
回答を追加する
Scott Darr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,895
