メインコンテンツにスキップ
LGによって製造されたAndroidスマートフォン用の修理ガイド
2310の回答 すべてを表示
How do I replace the sim reader in an LG P880 after I broke a prong?
i was inserting a micro sim in an adapter but it fell out. because the adapter has a recessed space for the sim. i had inserted the adapter far enough for the sim prongs to press up into the recess before i realised the sim was out of place. i tried to remove the adapter but it was stuck. instead of calmly thinking about what i was doing i got &%#*^@ off and yanked it out. the prongs came out with the adapter. i was able to bend two of them back in to position but one snapped off in the process. any ideas on a repair solution?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
Android 修理キット
A new screen or battery is one kit away.
ショップを見る
Android 修理キット
ショップを見る
1回答
選択されたソリューション
colroo1, it is soldered unto the board. It is available, just search for part EAG63193601. Of course, it will depend on where you live:-). So I would suggest to disassemble the phone, de-solder the old SIM reader and replace it. Not an easy job, but doable. Check this video if you need help with the disassembly. Hope this helps, good luck.
この回答は役に立ちましたか?
スコア 1
コメント:
thanks for the speedy reply . i was able to order the new SIM reader from rounded and the disassembly video was very helpful. i will disassemble the phone and de-solder the SIM reader tonight and wait for the new SIM reader to arrive 3-5 days, hopefully. cheers
による
Thank you for accepting my answer. Best of luck to you.
による
コメントを追加
回答を追加する
colroo1 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 835
