How do I get the data off the harddrive w/o power?
Will you recycle my laptop after the data is removed?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I only can answer the data question
you can use a external hard disk case or photo tank to plug the ide drive to a usb port.
i use an usb adaptor set for my data stuff - i can connect almost all types of harddisks to my system
このアンサーは役に立ちましたか?
photo tank?
yes photo tank - search for IAMOLED Photo Tank
it's nothing special, some are quite simple and are only to copy the pictures from the sd or cf card to the hdd - but the have an usb connector and you can use them as a external hdd.
the casings are pretty cheap and become very handy in those cases
Here's an adapter that works for me: http://eshop.macsales.com
Then I use a program called SuperDuper to copy the drive:
http://www.shirt-pocket.com/downloads/Su...
Here's where to contact iFixit to get a quote on your machine:
このアンサーは役に立ちましたか?
+ Ralph
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 918
