メインコンテンツにスキップ
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201回答 すべてを表示
締切られた回答
s2 not charging battery to 100%
S2 battery holder jack inside battery chamber.. Showing open circuit voltage..4.16only..no over heating any where...i hve already replaced usb flex ..bt same problem ...
On charging ..while m running heavy application ..battery goes down
Max battery charge voltage(closed circuit)4.012
Battery charger is ok... Nd delivering 5 volt on mother board
S2 model is i9100G
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I do believe that if you push these these phones hard enough, you can actually drain the battery even if you have it plugged in and "charging." I know one of my buddies did it downloading and gaming at the same one before. 4.16volts is kinda high for a 3.7 volt battery though. I've seen mine max at roughly 4.02 volts, but that's on a Galaxy S2 Skyrocket.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,720
