メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
water damage- black screen but phone still works
I dropped my phone in the pool about 6 months ago. After i got a new phone and put the water damaged on away. I just pulled the damaged phone out to see if it works and the phone turns on, i can play music by double tapping the home button and pressing around the play button, the voice control works, and it vibrates when it gets plugged into a charger. How do i get the screen to turn on, or how do i restart my phone? Any suggestions or help would really help, im in desperate need of my phone to work.
Thank you,
dillo
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It sounds like the connectors at the point where the motherboard & LCD connect have become corroded. You will needto open the back up and examine it with a magnifying glass for corrosion spots you'll need a experienced phone person to go through it with alcohol and clean the entire inner parts, and put them into a electrolysis cleaner. If by some merciless from above there was no water damage to the digitizer connectors or all the other parts that have had 6 months to rust away i would say clean your way through it with rubbing alcohol 93% and up you might get away with the cell phone crime Of the century. It may be a single cable connector loose or that has just enough corrosion on it that wiggling and wiping might restore the voltages. A cleaning by a local phone repair shop shouldn't be but $40-$60 bucks. Cheap for what he will be able to tell you about the amount of time you will be able to use the phone in the near future if your desperate fora phone. Might just be that you go on ebay and buy a LCD &digitizer & swap it out and it will work perfect. But it's all riding on what you find when you open that puppy up. Use the walk through tutorials on here and the u-tube videos to walk your way through the process there even ones on cleaning and fixing water damage.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 6,917
