メインコンテンツにスキップ
iMac G3 はオレンジ、ブルーベリー、ライム、グレープとストロベリーといったカラーバリエーションがあります。
18回答 すべてを表示
締切られた回答
Why won't the mouse work while the keyboard works?
Hi.
I recently got my hands on a neat iMac G3. While I was at it, I tried to install mac OS X leopard but it didn't work. So I just upgraded it to a newer version, mac OS 9.2, I think it was. After then my mouse has not worked while it did work before. Any clue what it the cause is and what I can do?
Thanks for answering while I'm at it :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
I will make the assumption you have a USB mouse plugged into the keyboard. Your computer will not run Leopard but should work well with 9.2. When you installed 9.2 did you format the drive? If not I would start over by formatting the drive and doing a fresh install. Ralph
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Checking Mactracker your computer will load Panther 10.3 which will give you many more options in software and more importantly in internet browsers. Ralph
さんによる
コメントを追加
最も参考になった回答
It can't be done. Because I can't move the mouse. Do anyone know a shortcommand for formatting the harddrive? Probably eh.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Open cd drive drawer and place system disk on tray--close tray. Power off by holding the power button until shutdown. Press the power button and the press the c on the keyboard and keep it pressed until the computer starts. Follow install instructions beginning with format the drive. This should clear your problem. Ralph
さんによる
I'm including the guide page for your computer. Your hard drive is how big and is the first partition 8 GB or less? Ralph
iMac G3 Model M4984
さんによる
I think it has less.
さんによる
コメントを追加
I've got my iMac 333 running fine on 10.4.11 with 512mb of RAM installed... Had to take out the hard drive and use another Mac to install it on that drive, due to 10.4 only coming on a DVD. But heck, I now have a scavenged DVD-ROM/CD-RW from a 550 Powerbook, running in there just fine. It can read and process data DVD's (such as installation disks), but the computer is not able to play DVD movies.
...and for 9.2, a quick browser is Classilla, which is basically a mobile browser which loads things very quickly... Thing of browsing the internet on your phone, but with a mouse, a real keyboard and decent-sized screen...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,613
