Red light comes on when I plug up my xbox?
When I connect my power cord up to my console the light goes from yellow to red on the power cord and the unit doesn't turn on.
Hi, most probably it is an issue with the power supply unit. Do u have access to another power supply unit, like one from a friend? Plug that in and see if that works ok. If that is ok then u would want to replace the psu. Did this happen after an intense session of gaming? Write back on what u did. Thanks.
このアンサーは役に立ちましたか?
I tried that one already saying results from the other power supply unit.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 539
Did you try anything else to fix the unit? I think I might also have that problem with my xbox 360.
Leia さんによる
