メインコンテンツにスキップ
Repair information for graphic tablets. Graphic tablets are also known as digitizers, drawing tablets, drawing pads, digital drawing tablets, pen tablets, or digital artboards.
33回答 すべてを表示
I need to purchase the 30 pin LVDS socket for this tablet's connector.
Stupid me bent a few pins in the lvds socket of a wacom 21 UX. I was since scouring the web to replace the socket that was broken, but came up empty handed.
Maybe someone could point me in the right direction. I've added photos of both the connector and the socket.
The socket seems to have a pitch of about .5mm also the connector seems to be a really small Dupont connector. (I can't find what this is called)
The lcd model is: nl160120bc27 by NEC.
The Connector.
Connector Again
Socket.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
any chance you could post an image of the connector and its location on the circuit board? Any numbers on your LCD panel that will help us to identify as much as possible?
さんによる
The recepticle seems to be something like this.
http://www.digikey.com/product-detail/en...
right angle surface mount pin connector.
I think it's a .5mm pitch instead of 1 though.
さんによる
コメントを追加
1 件の回答
選択されたソリューション
Yor1001, according to the datasheet for your panels it is a DF19G-30P-1H (59 or 99) (Hirose Electric Co., Ltd. (HRS)) available at places like this or even on here. Download the datasheet for the connectors from here. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thank You!!! That's definitely it!!! I forgot to check the datasheets... DUH. (I have it downloaded too)
さんによる
Thank you for accepting my answer. Best of luck to you.
さんによる
EDIT!! May I ask where did you find this connector in the datasheet, I've did a search and couldn't find any results?
さんによる
It is in the datasheet for your LCD. It shows the importance of posting as much information as possible.
さんによる
Yeah, I found it in the datasheet, it does show the importance or posting info. (I did post the pictures but did't realized I had to insert them into the posting), thanks again, just ordered the parts, now I hope I don't damage the pads more than how they are already damaged.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Yor1001 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,513
