Battery instead of optical drive?
Can I remove my DVD drive and add battery instead of it to my MBP? Thanks
MBP 17" Core 2 DUE late 2007
Update (04/13/2010)
Thanks all, I think i will get my DVD drive out and replace it with a HD.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi! That's a great idea, but unfortunately there's no way to do that. You can add a second hard drive instead of the optical drive, because a hard drive uses the same connector as the existing optical drive, but adding a second battery would require wiring and electronics that just don't exist in the computer, and as far as I know, no one has taken this on as a project.
このアンサーは役に立ちましたか?
Here's the guide for replacing the optical drive: MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement
Here's the optical bay adapter for use in another drive: [リンクされた製品が存在しない、もしくは無効: IF107-078]
Here's a SSD drive that might be of interest: http://www.ifixit.com/Mac-Parts/MacBook-...
このアンサーは役に立ちましたか?
Great research. +1 Ralph
Thanks but i'm looking for 17" not 15" !! not sure if they are the same but thanks any way.
hello. i am at the moment planning on doing such a mod using 2 batteries as i cant seem to get a hdd caddy working
ill post a new post once succes/failure arises
このアンサーは役に立ちましたか?
Physically fitting a battery is the easy part (still not that easy) the hard part is how you connect it to the logic boards power connections without blowing the logic. Without a complete redesign of the logic its just not possible.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 7,420
1件のコメント
Thanks for your reply, now since you said i can add a HD instead of my optical drive ( which i use 1 every 6 month ) where can i find the steps to do that? Thanks again
afendi27 さんによる
