メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
White screen, after replacing glass?
So i tried to repair my glass/digitizer and everything was fine until i saw the screen itself was defective since the replacement glass was not responding.
Me wanting to put back the old glass (it only had 1 crack) accidently pulled too hard on the suctioncup on the screen and ripped out the whole screen from all it's connectors on the motherboard. Luckily nothing was damaged from what i can see on the 1/2/3 wires, but now connector 3 has become loose in the sense that i can put it's wire in it and close it with the lock but i still comes out relatively easy, so i don't know if thats it.
After i switched those screens and connected everything i've gotten a white screen. (The sound still works though everything does actually except the screen itself)
I've read that i had to try and push on connector 1, straighten out the wires and clean them, but none of those things worked out.
I'm thinking it might be one of the connectors or the lcd itself might be the problem.
I hope you guys can help me with this though.
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Have you had the power disconnected or rebooted the device since the white screen started showing? Sometimes it just needs a restart to recalibrate the LCD.
If rebooting the phone(by holding home+power for 10sec) doesn't work, then the LCD is probably damaged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 478
