open surface pro and change ssd to 256gb ssd
ok after i opened surface pro and with metric duckload glue...... what kind of glue i should use to glue back the screen ?
or do i have to use the same old glue warm it up ? and reglue the screen with ?
Heating up and cutting the adhesive will most likely render it useless for resealing the device, so you'll probably want to scrape off the old adhesive with a plastic tool, and use foam double sided tape to reclose the device.
このアンサーは役に立ちましたか?
I have found that reheating and trying to reuse the old is useless. clean it, get a good 3m double sided adhesive strip set from ebay for like 14 bucks, and do it back together correctly. only way to solve future problems.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,690
