メインコンテンツにスキップ
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23回答 すべてを表示
The Netbook's monitor switches off andf stays off after boot
I cannot get my monitor to turn on on my notebook. It does so when booting then after the Xp logo appears it turns off. I have tried using Fn and then F4, but this makes no difference. It last worked today when viewing slides whilst the Notebook was connected to an AV porojector. When disconneceted from the projector and started again the Notebook's monitor would not remain on.
Please advise
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Older Hp laptops have a common issues of overheating and thus causing the gpu to become dislodged from the logic board. Doing a simple heat reflow and adding a copper shim between the heatsink and the gpu will help tremendously.
Im willing to bet that is your issue, even though you have video out, and some video locally, I think its on its way out. Eventually you will have no display but the computer will turn on, and you may or may not have video out.
If you google "Heat reflow on dv2000" you will find some forums explaining how to do it, and some videos as well. DO NOT USE PENNIES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you need more help let me know, it requires a heat gun, some type of heat shield ( I use aluminum foil), thermal paste, copper shims, and a precision driver set. All in all its not that difficult to do, just kind of a learning experience.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Many thanks. I think this ancient computer probably needs to be laid to rest. Your solution was both ingenius and most helpful.
Mick
さんによる
コメントを追加
回答を追加する
Mick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 460
