Screen sometimes comes on
My laptop dell has a problem . My problem is sometimes i see my screen and and other times no view . I hear the cd rom and hardrive .Try going in boot mode can get in . Need help .
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
vincenzomule , it is possible that this is caused by a bad inverter, bad LCD or broken display cable. Narrow it down by starting of with an external monitor. This way you know your GPU (video card) is okay.
このアンサーは役に立ちましたか?
Well i tried an external monitor no screen display .......
Since the external monitor has a different pathway then the LCD , it appears as if you are having GPU troubles. You could try a reflow of the motherboard and see if that will resolve it.
a repair tech told me it is the video card is that possible?
Yes, it is absolutely possible. your external monitor does not get any video, my suspicion is with a bad "video card" Here is the problem, the laptop does not have a dedicated video card, but it is part of the motherboard. This means you might have to replace the motherboard.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 334
