メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
metal pin in housing by the power switch - replacement methods?
Hello everyone.
I am having my back cover replaced to a bespoke one on my iphone 5.
the problem they are facing is this metal pin that is on the inside of the original housing.
this is not on the piece i have that im asking them to swap it with.
After some research i believe this is some sort of earthing pin and without this tiny little pin- the phone will not work.
Does anyone have any suggestions or tips to fix this or replace this pin
just to clarify
The new casing does not have this pin
The phone will not work without this
I have no spare pins
What has everyone else done?
your help - appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
最も参考になった回答
you will need 3 things, a small pair of side cutters, i mean small, a 6 inch screw driver and the small iphone pentalope screw driver.
to remove:
place aluminium casing on its back on a flat surface.
you can see the pin.
gently grip the pin using your small side cutters from the bottom of the pin
place your 6inch screw driver under the cutters and use the cutters as a falcrum
the pin will lift out gently.
to fit:
use your small pentelope screw driver and gently (using a screw motion) open the hole closer to the top, this will give the pin a bit more room and wont break the small casting when tapping the pin in.
tap the pin in gently until the top surface, this take in total around 1.5 minutes to do from start to finish.
good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
who the !&&* has microscopic side cutters...?
さんによる
コメントを追加
I had the same issue, though I don't know if its that important as they make it out to be, just use a sewing pin or something that fits in there, all I think it does is act as a hinge
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's just a structural support pin, No electrical function. Don't press the power switch too hard and nothing would happen.
If you really want to replace it, try extracting it from the original case and hammer it into the new one. You'll completely destroy the old one and risk wrecking the new one. But it is possible. I did it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Look on eBay, they are sold on there for about $3 including shipping. Here are a few links...
http://www.ebay.com/itm/191243768536?ssP...
http://www.ebay.com/itm/191243769572?ssP...
http://www.ebay.com/itm/191243769575?ssP...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
http://www.ipfix.dk/produkt/iphone-55s-o...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sally Kaur さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,888
