メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
iMac はAppleのデスクトップコンピューターのモデルラインです。
8566の回答 すべてを表示
restore to factory settings with no discs?
I want/need to restore my iMac but i didnt get any discs with it...i bought it used. Is there any way i can download a program to restore to factory settings?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
2件の回答
選択されたソリューション
NO - not download but you can purchase disks from Apple Support. Call 1-800-APL-CARE (1-800-275-2273).
If this Answer is helpful please remember to return and mark it Accepted.
この回答は役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Restoring an iMac is very easy in fact, if it's not too old device, even if no restoration disk. If you have no restoration disk, it is possible to restore your Mac over the internet. It should work for almost Mac (iMac, Macbook, Mac mini) produced since about Mid-2010. For device produced arround Mid-2010 to Early 2011, you may have to update the EFI Firmware. There is all the detail here : Computers that can be upgraded to use OS X Internet Recovery.
You have to start up the device holding "Command + R" and select the "Recovery HD". It will launch the recovery system. From here you can connect to internet even with wifi, access the disk utility and restore your system directly from Apple servers over the internet!
Please note that if you had a heavy crash disk or if want to change your system disk, the Recovery system is not available. In this case, when you will start-up your Mac using the "Command + R" a very simple system will be loaded and will allow you to connect to internet, even with a wifi connection, and to download the recovery system directly from Apple servers.
Finally if your Mac is running properly but you just want to restore, apple allow you to make your own recovery system.
Here are a few links with more detail information:
この回答は役に立ちましたか?
スコア 5
コメント:
Gaetan , you are correct about pressing Command+R when you hear the iMac boot chimes to launch the recovery system, but it is Option+Command+R when you hear the iMac boot chimes to launch the Internet recovery system. -XGempler
さんによる
That, apparently, depends on the state of the HD; I had two wiped HDs on a Mid 2010 Mac mini Server and accessed Internet Recovery with only Command+R.
さんによる
コメントを追加
回答を追加する
verona johnson さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 43
過去 30 日: 194
今までの合計 68,403
