メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
Replace the screen and iPod don't react anymore
Before tear off the screen the ipod works, but the glass was broken.
I did the same procedure as many times and by replacing the new screen the iPod don't react anymore. Also not on the pc or notebook.
First I thought the battery, so I replaced that also but no response and result.
What can it be, the logic board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Put the cracked screen back in and see if it works maybe the new one is a dead one
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I already replace the cracked screen and still the same problem. Doesn't work and Itunes or PC don't reagornize the iPod. I also tried new screen, but still not working. What can it be?
さんによる
コメントを追加
I concur with the above answer.. Too many times, I get bad digitizers, right out of the package. I have even had the digitizers and the connectors come out of the bag, completely separated and obviously never working.. Hint: When taking apart the iphones, ipads or ipods, always try to salvage the digitizer, that is do not break it in case you get a bad one. Of course, having another one or two new digi's around is nice and makes checking things a lot easier, for someone doing a one-time fix, buying extras is out of the question. Plus, a test box to test digitizers is over 1300.00, and not many shops even buy them.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 228
