より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1961の回答 すべて表示
No charging after Battery replacement
Hello,
I have the following problem:
My iPhone can be used only with connected charger because the battery life was shortened to 5 minutes.
I suspected a defective Battery. I have ordered a new one, but unfortunately with the wrong APN. I could charge the iPhone only if it was turned off. Of course, I immediately ordered a new battery that has the correct APN.
After I installed the battery with the correct APN, I can not charge the battery. The plug icon but not the lighning symbol appears.
I've read that might have something to do with fuses. I checked the fuse. They are ok.
I hope you can help me.
Thank you = D
Sorry for bad english. My native language is german =P
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Which fuses did you check and how did you check those?
による
コメントを追加
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
1回答
選択されたソリューション
Marcel Hering, first make sure that you have a known good cable. Try to charge it from an AC charger, it will provide a higher amperage than a USB port. Clean your dock connector. Use some isopropyl alcohol and a few puffs of compressed air should work. Check for broken, bend or corroded pins.If this still does not work, replace your dock connector by following this guide. If after that you still have issues, you may have to take a look at the PMIC and that may require some board level repair. Hope this helps, good luck.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marcel Hering さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 216
