メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2996の回答 すべて表示
HELP! Home button is not working due to water damage
I have recently dropped my iPhone into my cup of tea and now the home button does not work. The top half of the phone did not come into contact with any water, it's just the bottom half.
The phone still functions, however the home button does not work and the speakers are a little crackly (i'm not to bothered about the speakers, I can live with that!)
When I place the button to my ear I can hear a a sort of noise - any ideas on what this may be?
It's been on the radiator..in a bag of rice, you name it, i've tried it!
All in all, I was wondering if anybody could suggest any ideas or solutions. Do i need to get it repaired professionally or are there any solutions that I could try at home?
Any ideas would be much appreciated
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
選択されたソリューション
Gwen, the very first thing to do is to clean your phone. Rice and the radiator will not prevent any corrosion, nor will it clean the phone. Use this guide to disassemble your phone. It is not as difficult as you might think. Once it is disassembled, use this guide to properly clean your phone. Once cleaned, replace your battery and re-assemble and re-evaluate. It is possible that you need to replace the home button or even the home button flex, follow this guide. Like I said before, it is not as difficult as it might appear. Hope this help good luck.
iPhone画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
iPhone 4S ロジックボード画像
ガイド
iPhone 4S のロジックボードの交換
難易度:
難しい
1 hour
iPhone 4S ホームボタンリボンケーブル画像
ガイド
iPhone 4S ホームボタンリボンケーブルの交換
難易度:
難しい
2 - 3 hours
この回答は役に立ちましたか?
スコア 0
コメント:
I will certainly give this a go, thank you so much!
による
Gwen, thank you for accepting my answer. Just follow the great ifixit guide and you should be okay. If you have any issues after that, let us know with new questions:-)
による
コメントを追加
There could be damage/corrosion on the home button circuit or on the dock (The home plugs into the dock module, which plugs into the circuit board). If you are comfortable and have the tools, you can open up the phone and have a look at the dock to see if you see nay corrosion. Examining the home button circuit will be a little trickier, as you have to completely take the phone apart to see the entire home button circuit. If you do see any corrosion, you can attempt to clean it using a brush (like an old tooth brush) and Isopropyl Alcohol.
If you are not so comfortable with taking it apart, there are several repair company's out there that specialize in iPhone repairs and would be able to help you. They are just one Google search away.
この回答は役に立ちましたか?
スコア 0
コメント:
Thank you for your feedback.
So is that serious or can it be resolved easily? and is there any way that this problem can be resolved at home? I live in Wales and there aren't many reliable phone repair shops around so I may need to go further afield!
による
コメントを追加
Hi Gwen you ever get this sorted?
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gwen さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 29,931
