メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1489回答 すべてを表示
It said iPhone disabled connect to itunes
It told me to unlock it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 60
10 件のコメント
my iphone3gs is lock
さんによる
My iPhone 4 is lock
さんによる
I have a A1303 Apple IPhone and it is locked on Connect ti iTunes and showing USB CONNECT TO LAPTOP. Before I open it, it state iOS6 ?? I have held both the home and power button down for 10 sec after turning the iP off and releasing the power button after 10 secs but nothing happens.
さんによる
i phone is disable to connect itune
さんによる
iphone is disabled
how i do open this lock
さんによる
5件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
toby gray, put your iPhone in DFU mode and Restore with iTunes:
Connect your iPhone to your computer
Turn your iPod off
For 10 seconds, hold both the Home and Power buttons
While still holding the home button down, release the power button only Continue to hold the home button down for an additional 10 seconds. After the dialog box explaining that the iPhone was found in recovery mode has been closed, restore your iPhone. Bad part with this is that you are going to erase the information that has been collecting on your phone since the last backup. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 16
4 件のコメント:
thank you so much for the helppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! it took me so long to find the answer and i looked it up on google and this website popped up and it was soo so so so helful, agian THANK YOU!!!!!
さんによる
you can also just power off the device and hold home button down as you connect it to force it into recovery mode, and then restore with itunes... again all data will be lost , this is easier than DFU mode
さんによる
thank you soooooooooo much!!!
さんによる
tnakyou so much for your help
さんによる
コメントを追加
Connect your iPhone to a windows laptop or computer.
If that doesn't work then try something else.
I really hope this works for you guys because it definitely worked for me.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Turn your iPod off
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I am trying to unlock my mom's iPhone 4. She passed away a year ago. I tried different things and now it says "iPhone disabled connect to iTunes ". Tried that and did not work! I really need some help here. Trying to get this done and give it to a cousin who is down on his luck and needs this phone. Thanks in advance!!
さんによる
It's disgusting that apple did this, such a critical issue with data stored getting lost. I surprised
さんによる
コメントを追加
回答を追加する
toby gray さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 36,262
