No external sound aside from ringsignal.
So I've been reading a bit on this issue on my own over on apple's support community, and the fixes has usually been to turn the phone in to a Genius and have it replaced ..
However, it's a non-option for me so..
Background : The phone was exposed to water, which caused issues with it not recognizing simcard's, an issue which i did fix.
What's causing this issue?:
I can hear the ringsignal just fine, due to lack of sim however I can't test if the speaker goes off when it's being called.
When i press the volume button it adjusts the volume of the ringer, but doesn't show any indicator bars (those dots under the speaker icon)
I tried cleaning the headphone jack to no avail, and when i plug in a headset, i do get sound ..
So what should i replace here? Dock connector, as the the phone might think it's docked (does it actually emit sound thru the dockport at all though?)?
Headphone jack, because the sensor's not indicating that the headphones are unplugged?
I've long since solved this, essentially it mandated I replaced the dock connector, Once i had, everything was working perfectly gain, and my client was over the moon.
MobiFix さんによる
