メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
Monitor won't come on, power brick good, fixable?
My UPS just died, no sound, just shut off and at the same time the Cinema display went dark. Plugging it directly into the wall did nothing (no power light). Figuring it was a surge that killed the power brick, I bought a new power supply.
So, even when using the new power supply plugged into the wall the power-on light on the monitor remains dark.
My regular repair shop says can't be fixed, but I noted that mother/inverter boards are only $50 online. Can anyone tell me if they are mistaken and that it can be fixed or does it sound like time to take it to the recycling dump? (i.e. replace inverter board).
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
Is there any youtube on this? I have my cinema display disassembled, I have the multimeter, and I'm aware of certain points to try, but I get nothing so I'm not sure if I'm missing a step somewhere in all of this. I can't determine if my logic board is dead or powersupply isn't feeding enough.
さんによる
Logically, this machine is a power supply, hooked up to a brain, hooked up to a giant pixel display, with some lights and other plumbing.
You know the power supply is good. Are the lights good? If no, maybe it's the internal power supply stuff that powers the lights. If yes, it might be the brain.
If any of the wiring looks worn/damaged, replace it, but this is pretty rare, since nothing internal moves.
さんによる
コメントを追加
1 件の回答
ベストアンサー
An inverter won't help if you're not getting power. Use a multimeter to test and trace down your power route. Here's one in case you don't have it: Digital Multimeter
Versatile multimeter with all the right functions for basic electronics troubleshooting.の画像
製品
Digital Multimeter
$59.95
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ejsprung さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 7,747
