メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
Upper mic doesn't work
Hi.
I've followed the Iphone 4 home button replacement button.
Everything works BUT the upper mic!
No sound while video recording and people can't hear me when i put them on speaker while making a call.
I gues something is not connected right, becuase I haven't had that issue, and i don't think i have damaged any ribon cable.
PLEASE HELP.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
If your upper mic doesnt work. Try going to your settings and updating the software. If it doesnt work. Listen to videos or recordings to try it out. If it doesnt work try plugging your computer into a computer. If you dont have one try listening to the downwards mic to check. IF they all dont work there is NO way to fix it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I don't understand your answer.
"plugging your computer into a computer"?
and there is nothing that "there is NO way to fix"
Please, I want some kind of more helpfull reply about this.
さんによる
コメントを追加
There is a way to fix it. If you can make calls normally, you are using the connector dock as your mic. However, when on skype, facetime, video messages, you are using the headphone jack mic located at the top of the iphone. You need to replace the headphone jack/power/volume ribbon.
I don't know why Cookies says there is no way to fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tan Tan, since your first suggestion is the common-sense recommendation of checking the settings, I would also add that a screen protector or new lcd replacement film has been removed or is not covering the microphone.
Agreed inline with checking apps is to go to the voice recorder and try recording your voice. Speak loudly and could verify by sending the sound bit to your computer where you know sound works.
Also if it's in a case that's cheaply made and generic. I've seen loads sold on eBay before that were being dumped because of manufacture error and people buy because their $1.
Oh the days of selling iPhones on eBay. Can't help but remember all those calls about faulty cameras showing a green image to find out the original lens protector had not been removed yet.
I'm a little confused because OP says upper "microphone". Wouldn't this be the upper earpiece?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 527
