How to take out back glass parts
On iPhone5 how is possible to remove the glass parts on top and bottom? are they glued?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yup, they're glued in place. Apple used some pretty serious adhesive to hold them in, but it's nothing that a heat gun wont soften. Picking them out from the back is not possible, so you have to heat them up then push them out from the inside. The main problem with removing them is that you have to remove just about every other component in the iPhone to get to them, which is a real pain.
この回答は役に立ちましたか?
Heard anything to the effect of using a form of glass chip repair to fill in a cracked/chipped glas back panel on iphone 5?
Similiar to how a chip is repaired on the windshields on cars and trucks these days. Basically a form of epoxy and on quarter size chips and smaller a suction cup style plunger combination is used to inject the epoxy into the cracks.
この回答は役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,274
