メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
147回答 すべてを表示
MacBook Air 13" won't boot up
Problem:
I press the power button, the boot sounds, white screen with apple logo shows up, process bar moves and the "wait" symbol turns around. However, when the process bar moves to about 15%, it disappear. And then computer turns down. It won't boot to OS. I press the power button and the Mac goes the same loop.
Specification:
MacBook Air 13"
Model: A1369
CPU: Core 2 Duo 1.86 GHz
Flash: 128 GB
What I have tired:
1. I tired SMC for few times, but it did not work out.
2. ⌘-⌥-P-R to reset, but it did not work out.
Can anyone help me to find the root cause of this issue? What else I can do to fix it? thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Sounds like a corrupted system folder or an incomplete update in progress and looping. Try starting up from your original system installation disk and running Disk Utilities on it to repair the system.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Thank you for the answer, Mayer! I do not have the "original system installation disk". In this case, can I download it from somewhere and make one USB drive by myself? Thanks~
さんによる
Sounds great, would like to know what they did & charged??
さんによる
They reloaded the OS to the factory settings. All my documents and photos are lost. It is okay because I use cloud storage. The charge is FREE :) because it is a "software repair". My unit is out of warranty.
さんによる
コメントを追加
Are you able to safe boot your system? If it does you can run disk utility to check your disk permissions. However, in case it is beyond disk utility repair then try to boot it with the installation disk that came with the Mac.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I tired starting up in Safe Mode, following http://support.apple.com/kb/HT1455, but it did not work. Do you know how to make the installation disk in case I have lost the original one? thanks!
さんによる
Well, I am not sure if you can make it but can purchase replacements from AppleCare.
さんによる
I visited the local apple store and they help me re-install the OS to the update to date version. The MacBook air is back to live!
さんによる
lost all data or some part of it? Anyways a re-install is always hectic.
さんによる
コメントを追加
If nothing happens when you push the power button, it generally is one lousy drop of fluid that hit that button. They are very sensitive to liquids on them. Nothing happening is not the same as not booting, and if you get no reaction at all, it is an issue with the power button. No boot disk can help you then, and the upper unit needs to be replaced.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Shawn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 20,189
