Why is my iMac randomly going to sleep?
My iMac began randomly going to sleep a month ago. I reset the SMC multiple times. It stopped doing it for 2 1/2 weeks. Then it went another week without doing it. Now it's done it 10 times in the last 2 hours. Any ideas why? it does it while I use it and I have to use the power button to wake it up.
Console:
1/22/13 4:53:00.218 AM powerd: PMScheduleWakeEventChooseBest: m=0.00 s=0.00 a=0.00
1/22/13 4:53:06.000 AM kernel: AppleBCM5701Ethernet: 1 4 compare_link_settings - failed flowcontrol check
1/22/13 4:53:06.000 AM kernel: Ethernet [AppleBCM5701Ethernet]: Link down on en0 (wol enabled)
1/22/13 4:53:07.000 AM kernel: Ethernet [AppleBCM5701Ethernet]: Link up on en0, 100-Megabit, Full-duplex, No flow-control, Debug [796d,2301,0181,0000,45e1,0000]
1/22/13 4:53:07.733 AM configd: arp_client_transmit(en0) failed, Network is down (50)
1/22/13 4:53:07.733 AM configd: bootp_session_transmit: bpf_write(en0) failed: Network is down (50)
1/22/13 4:53:07.733 AM configd: DHCP en0: INIT-REBOOT transmit failed
1/22/13 4:53:07.733 AM configd: LINKLOCAL en0: parent has no IP
1/22/13 4:53:07.733 AM configd: DHCP en0: ARP detect ROUTER failed, arp_client_transmit(en0) failed, Network is down (50)
1/22/13 4:53:07.824 AM applepushserviced: <APSCourier: 0x7fcdde004a70>: Stream error occurred for <APSTCPStream: 0x7fcdda606e80>: The operation couldn’t be completed. Socket is not connected
1/22/13 4:53:07.000 AM kernel: SMC::smcGetKeyInfoAction ERROR CLWK kSMCKeyNotFound(0x84) fKeyHashTable=0x0xffffff8012247000
1/22/13 4:53:07.832 AM configd: network configuration changed.
1/22/13 4:53:07.832 AM applepushserviced: <APSCourier: 0x7fcdde004a70>: Stream error occurred for <APSTCPStream: 0x10e3364e0>: The operation couldn’t be completed. (kCFErrorDomainCFNetwork error 2.)
1/22/13 4:53:17.000 AM kernel: Wake reason: PWRB (User)
1/22/13 4:53:17.000 AM kernel: Previous Sleep Cause: 5
1/22/13 4:53:17.000 AM kernel: 2847.948783: setDISASSOC from ATH_INTERFACE_CLASS disconnectVap
1/22/13 4:53:17.000 AM kernel: 2847.948791: switchVap from 1 to 1
1/22/13 4:53:18.000 AM kernel: AppleBCM5701::selectMedium - autoselect, any duplex, flow control allowed
1/22/13 4:53:18.000 AM kernel: Ethernet [AppleBCM5701Ethernet]: Link down on en0
1/22/13 4:53:18.228 AM hidd: MultitouchHID: device bootloaded
1/22/13 4:53:19.000 AM kernel: Ethernet [AppleBCM5701Ethernet]: Link up on en0, 100-Megabit, Full-duplex, Symmetric flow-control, Debug [796d,2301,0de1,0300,45e1,0000]
1/22/13 4:53:22.222 AM configd: network configuration changed.
この質問は役に立ちましたか?
2 件のコメント
I believed it is the latest upgrade from apple because i have two partitions one i use and the other is backup, when the problem started I switched partitions and the problem went away
freddy さんによる
Found the problem! i placed a jumper on my sata HD drive selection between pin 1&2, restarted and abracadabra, it worked for me, my mac was going to sleep every three minutes now, no more problems
freddy さんによる
