メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53回答 すべてを表示
How do I remove old door speakers?
After removing door panel. How do I remove old speaker. And connect new speakers?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
haleymueck, the speakers are screwed to the door with either 2 or 4 (depending on model) screws. Unscrew those and slightly pull the speaker out of the door. The wires should be connected with some spade connectors. Remove those, but do remember to write down which cable goes on the + of the speaker. Your speaker is most likely has the marks for the polarity by the connectors. Once disconnected, just replace that speaker with a new one. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
haleymueck さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 320
