メインコンテンツにスキップ
The original Blackberry Bold smartphone, featuring various improvements from older Blackberry models.
11回答 すべてを表示
What can damage my blackberry power management ic?
My blackberry 9000 was working perfectly without any problems but the battery drained and it suddenly switched off, i looked for the charger, (weak charger) and i kept the phone on it till it started again, there was a message and i wanted to read it, so i started chatting again, and the phone turned off again, i left it to charge so it started but this time when it started i just put it on stand by mode and went to sleep, in the morning it wasn't working at all, and when i do a battery pull and place it back, the red LED comes on for 10 seconds then nothing else happens, i took it to a shop and they told me that the Power Management IC has to be replaced, it cost me US $40 and my friends told me it will happen a lot, so how to avoid this happening again ? It also fell 3-4 times the same day, and i used it once with my wet hand. So which one of these the reason for damaging the Power IC, or is there other reasons ?
Thanks In Advance !
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Jigsawh, there are multiple reasons why this can happen. From bad soldering, cracked solder connection, to a bad manufacturing of the part. None of this is uncommon. Of course dropping it and " fell 3-4 times the same day" does not help it any:-), the least likely reason is this "used it once with my wet hand." The number one reason for it are cheap and unsafe aftermarket chargers. I suggest to always get an original charger. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jigsawh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 3,233
