メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
429回答 すべてを表示
Can I make a fusion drive in my iMac with OSX 10.8.2?
I see on Macworld how to make a fusion drive http://www.macworld.com/article/2014011/... but that is on a Mac mini 2012 and I want to know if I can do it in my iMac 21.5" EMC 2428 with Mac OSX 10.8.2 after I install a ssd on it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
if you asked Apple they must suggest you to buy their new iMac LOL
さんによる
コメントを追加
3件の回答
ベストアンサー
Some people have had success with early Mac Mini's '11 Mac Mini Info. Yet, others have not been able to get a MBP working: '11 MBP info.
I suspect there is some firmware issues on some systems. Sadly Apple has not disclosed what systems work and which don't so you will have to just give it a try. Please do let us know if you were able to make it work.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I made it work with a 21.5 in. 2011 iMac with a Crucial 256 gb M4 SSD and stock 1 TB HD. I found instructions on the web using the Terminal program. I am running the latest OS and my machine screams now. I activated Trim Support using a shareware program. Even About My Mac recognizes it as a Fusion Drive.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Your correct! Most any Mac can be configured with a Fusion drive using the terminal commands in OS-X Mountain Lion. When I wrote the above answer we didn't know about how systems that didn't have the BIOS support could be setup.
さんによる
コメントを追加
I can confirm this, i've been using / upgrading (up to 10.9.1) my 21.5 mid 2011 imac without any problem with a fusion drive made from terminal commands, the stock 500Go HD and a vertex 3 SSD.
Absolutely nothing to say except it rocks !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jimenezser さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,400
