メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
Music plays only one side of the headphones?
I have tried multiple headphones, but I can only hear the music on one side of the headphones; so, the problem isn't the headphones, it is the ipod touch itself. If I plug the headphones in all the way, it only plays on one side, and if I just barely plug it in- just touch the output, then it plays on both sides. But, it has become incredibly difficult for me to listen to the songs with the headphones plugged in all the way, and its way too hard to listen to it, carefully keeping watch for the positioning of the wire. Please help me fix this problem, so that I too can completely take advantage of the Ipod Touch. It has only been a year, and this ipod has gone wrong within less than a year after purchase. Hope the description helps solve my problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
Neeru,
It sounds like the Jack or solder connection from the jack to the board is faulty. Unfortunately there is no quick solution for this issue. It will require a disassemble to diagnose accurately.
-Cheers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
try to clean it with a few puffs of compressed air. Also, insert and remove the jack a couple of times in rapid succession. It does sound like one of the contacts is stuck and does not make contact.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the Same problem . Get a paper clip and just pish it around for a while plug in ur headphones and it should work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Neeru Darling さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 7,657
