jumbled buttons,broken wireless controller
hi,my wireless controller has lost the use of a/green button and the rt button now has controll of the a/green button,can it be fixed
Did you get it wet or spill something on it? If the right button is now doing the function of the A button, it sounds like something shorted inside the controller. You could take it apart and see if it is corroded inside, or if it is wet. If it is, clean it up and let it dry out before you put it back together and see if that fixes it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 239
Your green button does no longer work and which button is the "rt" button? Is is the right or the red button? Not sure about your abbreviation. When did this start and what have you tried to fix it?
oldturkey03 さんによる
